valver phase 2 exhaust
greendale65
Post by greendale65 »
Hello all, may be looking for back box for my valver
seem to be thing on the ground walkers seem to
have run out only option stainless steel.
one with straight tail end would be good.
8) 8)
Re: valver phase 2
You can take an estate backbox and cut the tailpipe off, but it won't be all pretty and chrome (or black, if you're going OE) unless you bolt a trim on.
Re: valver phase 2
Kitch wrote: Thu Jul 06, 2017 2:27 pm You can take an estate backbox and cut the tailpipe off, but it won't be all pretty and chrome (or black, if you're going OE) unless you bolt a trim on.
It can look OE good using an estate back box. The Doc did one for my GTi and as the cut pipe comes out too straight and can therefore knock on the bumper he cut a V out of the pipe too and welded the V shut so it then had a smart bend to it. The Doc though can be considered a bit of a magician in practical matters pertaining to the BX and bigger stuff! 8)
