Welding
womble3go
Welding
Post by womble3go »
I need to do some welding to the car for the MOT I know about disconnecting the battery and start and alternator, but never had one with ABS do I need disconnect the ABS unit or will it be ok? Thanks for the help on this.
Re: Welding
I've never done it on mine, but it's so easy to do you might as well!
senmathal
My Cars: Citroen BX 16 Valve 89, Citroen C5 HDI 163 -12
Re: Welding
Post by senmathal »
If so even the engine computer as well? But I don´t think it´s necessary. Most important is to be careful where to put the earth clamp. As close to the welding area as possible and with good contact.
/Mats
Re: Welding
Its only a 10mm nut and as long as the radio is not coded its probably wise.
