my 4x4 fuel tank sender unit has cracked and sprung a leak so i am now off the road until i can find one. i've tried my local factors and ebay to no avail.
does anybody have one? it's just a sender unit with two pipe connectors and no pump, the maker on mine is jaeger with two numbers on it 33784401 and 9603540380. thanks, barry
sender unit
barry badger
sender unit
1993 tzd estate, on sorn
1992 txd estate, on the road
1991 4x4 estate, on the road
barry badger
Re: sender unit
Still after one of these, my temporary repair has just failed so off the road again. My propshaft bearing is bad so haven't been able to go far in this for a while anyway. Have been trying to resurrect my tzd so that i can take this off the road to attend to the lengthening repair list.
- x 116
Re: sender unit
I might have a dodgy one that you could cannibalise the housing from. I will dig it out and see if it is a Jaeger.
barry badger
Re: sender unit
Ok thanks, it would be brilliant if you have one.
- x 116
Re: sender unit
I can only lay my hands on one, its a Veglia so no good for you plus I should really keep it myself as a spare. You could use one of your diesel ones to get you on the road again.
