BX Diesel automatic not starting
Occasionally, my BX Diesel refuses to start. Engine does not turn. It always starts on the second attempt. There is no clicking. Occurs when starting cold or hot, once every 2 to 3 weeks. I was using the car daily for work, now drive it 2 to 3 times per week.
I replaced glow plugs 2 months ago. All the connections to battery, alternator and starter motor have been cleaned, and are secure.
Not sure if it is starter motor, or one of the plug in relays underneath the glove box. If it is the latter, which relay would it be?
65 Peugeot Boxer work van 280k - x 121
Re: BX Diesel automatic not starting
I would suspect these first. Faulty solenoid on starter motor, worn ignition switch both of these can give intermittent starting issues both easily checked with a multimeter, I had same issues with my diesel turns out it was a worn ignition switch but only after a new starter was fitted, I found mine played up more during the winter. Should you need any of the above I'm sure I have some switches and several starters used but tested.
[quote=rutter123 post_id=264332 time=1516534896 user_id=3200]
Many thanks. Will test solenoid and switch.
- My Cars: BX GTi, C3 Auto
- x 50
I cured mine of exactly this problem by running a lead from the ignition switch , cable 3 I think, direct to the starter solenoid.
This was after changing starter motor , cleaning all connections and putting up with it for far too long.
I tried fitting a push button starter switch too. This worked but upset the ABS ECU so that was a non starter.
Many thanks for the advice
Continuing to have non starting on the BX Diesel automatic.
Attempted to start 5 times without avail. Put transmission into N instead of P and started instantly.
Same happened later on.
Then started fine in P.
Wondering if non starting related to automatic gearbox fault.
Previously had a faulty fuel filter housing (now resolved), and was cutting out and restarted the car 5 times each journey on the daily commute. Possibly caused strain on the ignition switch/starter motor.
Any ideas/advice gratefully received
Yes automatics have an inhibitor switch on them that prevent you cranking when in drive or reverse. I would imagine this is your fault. Might just need the connector cleaning. It is located on the gear selector IIRC.
Edit quick search brought this up:
"it is a combined switch on an auto does both, rev lamps and gearbox lock out, it is located on the front top of gearbox with a 4 way plug connector."
Defender110 wrote: ↑Fri Jan 26, 2018 1:39 pmYes automatics have an inhibitor switch on them that prevent you cranking when in drive or reverse. I would imagine this is your fault. Might just need the connector cleaning. It is located on the gear selector IIRC.
Thanks very much for your help
Will give it a good clean (and if necessary replace) this weekend
Many thanks. Cleaned up the terminals with wire brush, applied copper grease, and now starts perfectly - in P and N!
I'm considering getting a spare inhibitor switch for the future. Is the combined reverse/inhibitor switch on automatic BXs the same as the reverse switch on manual BXs?
No it won't be, as defender 110 says on the auto it is a combined switch incorporating the gearbox lock out and rev light switch on the manual it's purely a rev light switch, I may have a spare 4 pole auto switch somewhere if needed let me know if you still need the ignition switch.
rutter123 wrote: ↑Mon Jan 29, 2018 4:50 pmNo it won't be, as defender 110 says on the auto it is a combined switch incorporating the gearbox lock out and rev light switch on the manual it's purely a rev light switch, I may have a spare 4 pole auto switch somewhere if needed let me know if you still need the ignition switch.
Many thanks. I've ordered the correct switch. I'll hang fire on the ignition switch for the time being.
Upon further investigation, it appears that the automatic gearbox selector is at fault.
When in Park, the selector lever on top of the automatic gearbox at the front is not in the forward most position; it is actually in reverse, hence the car wont start in reverse. I pulled the lever forward, so it is in the Park position. and the car starts instantly. I've done this a few times, to ensure it's not a blip.
Any ideas on how to adjust the automatic gearbox selector mechanism?
- x 26
Before the Automatic box gave out on my car, I had trouble with the selector and non starting issues. The two bolts (or screws, I don't remeber exactly) holding the selector cable came loose so it could move around resulting in the gearbox not being in the gear that was actually shown. Might I suggest checking these bolts on top of the gearbox to see if they are at fault.
I also had an electrical issue that stopped it starting, it would click as if the starter was faulty, but remained the same after I replaced the starter. It turned out to be the wires that go to a relay behind the air filter box; they had rubbed through and were shorting on the body. They connect to the gearbox inhibitor switch and connect between the starter motor wire. Once I removed them because of the different gearbox I had no further issues.
Hope that helps.
Hope that helps.
David wrote: ↑Sat Jun 23, 2018 11:36 pmBefore the Automatic box gave out on my car, I had trouble with the selector and non starting issues. The two bolts (or screws, I don't remeber exactly) holding the selector cable came loose so it could move around resulting in the gearbox not being in the gear that was actually shown. Might I suggest checking these bolts on top of the gearbox to see if they are at fault.
Hope that helps.
Thanks for the info. The two studs (which appear to be tapped in place) had broken, so I replaced them with 2 x 8 mm nuts and bolts. It's been fine ever since. I cleaned up the inhibitor switch connectors and wires while I was working in this area. I also purchased a new inhibitor switch should this be needed in the future. Part numbers and dimensions:-
CITROEN:- 501310319 or 225729
79880RMP
Calorstat: XRLS 130 5022515133139 6153 08E (X1)
PEUGEOT P225729 (Also fits Peugeot 505 3HP22 Automatic transmission)
THREAD SIZE:- M18 x 1.5
SPANNER SIZE: 27 mm
Often available on Ebay.
