Re: Valver
greendale65
Re: Valver
Post by greendale65 »
Hello all, can somebody explain how this water gets here laying on top of rubber door seal when its been raining?
Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
x 82
Re: Re: Valver
Post by Dave_16v »
Is it travelling along from the sunroof tube outlet which is located behind the vertical panel to the right of the accelerator. The water may not be fully escaping at the sill. Have a check around that area, the tube empties into the sill but if any dirt has built it may be the source. It is a while since I have done much on the BX so working from memory a fair bit.
greendale65
Re: Re: Valver
Thanks Dave , gives me some thing to go on
soon as i can will check that out its about the
only thing not checked .
Dave_16v
BX Gti past
BX Gti Auto past
x 82
Re: Re: Valver
Post by Dave_16v »
You are welcome Alan, hope you find the source whatever it turns out to be.
x 138
Re: Re: Valver
Post by rutter123 »
I would suspect that the front drain tubes are blocked at the top end, had this on mine when right hand cornering i could see water escaping from the headlining above the front passenger door due to blocked drain tubes. Worth checking the rear tubes as well. They are quite fiddly to locate but once you get to them just blowing up the tube will usually dislodge any debris.
greendale65
Re: Re: Valver
Thanks all, will get to it better weather to cold at mo.
