Rear arm
Rear arm
I have a brand new rear suspension arm offside for sale, bare carcass no bearings fitted, genuine part
Make me an offer
Postage £8 UK mainland
Make me an offer
Re: Rear arm
Offers in the region of?
Re: Rear arm
Re: Rear arm
My mistake it does have bearings in but no hub bearing, it is marked with part number 40 X 65 is new has never been fitted and the bearings are rust free.
Defender 110 how does £30 grab ya?
Re: Rear arm
I have loads of rear arms here some have bearings some need rebuild , most have hubs on and discs, I have about 6 nearside and 6 offside some ABS with sensors but sensor condition/worthiness unknown, I also have 6 rear struts which as far as I know are ok with no leaks but these are from hatchback unsuitable for estates unless you want a really bouncy ride.
- My Cars: BX17TGD
ZX19d Avantage
Re: Rear arm
Howmuch would you want for a pair of s/h arms that were rebuildable please?
Re: Rear arm
Hi Dean , ABS on non ABS, I've prob got a pair that have bearings in and usable without rebuilding, I'll have a look see wot I got.
Re: Rear arm
Yes I got a good pair here bearings look good too, also the hub bearings seem ok, I'd say you could fit these straight on
£40 pair plus post or collect from PE12,
Re: Rear arm
Hello Rutter,
is there any possibility to send a pair to germany at a reasonable price...?
Finding good arms is quite hard and mine are totally over...
Re: Rear arm
Hi Steve yeah I can do that no probs, I will check shipping charges but I think it works out better if I send them as 2 parcels as each is under 10kg it's better rates.
Re: Rear arm
Ok, sounds logic -thank you for that!
Re: Rear arm
Steve, shipping to you will be about £18 based on a max weight of 20kg, this is the pair sent together, I don't have an accurate way to measure the weight but I'm guessing they are under 10kg each. Post service will take 4-5 days.
Re: Rear arm
Thank you, i will PM you!
Re: Rear arm
Cheers Rutter,
i just overhauled my rear arms last weekend, turns out the bearings where totally scrap but arms itselfs where good to go. So i don't have no need for - but many thanks! Anyway you have some other stuff i am interested in, i will tell you later.
Have a nice day
Steve
Have a nice day
Steve
- My Cars: BX 1.4 1991 daily driver. BX 1.4 1989 off the road. Rover P4 1963.
Rover 25 2004, Morris Mini Traveller 1966, VW Golf Convertible 1985: all
these cars are stored off road
Re: Rear arm
Hello there. Do you still have the Rear Arm for sale? I want to sort both rears on mine and understand that the casting can get damaged. I can be
phoned on 01242 704881 or 07917208614 in the evenings. Thanks for your attention Mark R,,
1.4 Driver
