XUD9 cambelt tensioner
Dyane425
How many cambelt tensioners does the XUD9 engine have on a BX19 Diesel Non turbo? If more than one, is it the same part number for both?
Re: XUD9 cambelt tensioner
It only has one tensioner and one idler pulley.
Dyane425
Many thanks
pwykes
The cam belt tensioner is spring loaded, after fitting a new timing belt turn the engine over manually using the front righthand wheel in a forward direction with 3rd gear engaged before permenantly locking down the tensioner with the securing nut.
Dyane425
Thanks
pwykes wrote: Mon Apr 16, 2018 9:54 pm The cam belt tensioner is spring loaded, after fitting a new timing belt turn the engine over manually using the front righthand wheel in a forward direction with 3rd gear engaged before permenantly locking down the tensioner with the securing nut.
