Hi folks
Apologies for making this my first post, my car came to me with one of your stickers in the glove box & I had meant to register and post before this, but...
My 19RD estate has just been at the garage to have a leaking height corrector replaced, on going to do this they discovered that one of the aforementioned pipes is leaking badly & the other three are 'not too clever', apparently. They don't have flaring tools for making the pipes up, but are happy to do the work if I can source a set of pipes. Getting them made doesn't appear too difficult - I found this pretty quickly:
http://www.eurocarcare.net/lhm-hydrauli ... -made.html
but my problem is that I don't know the lengths of the pipes. If anyone can tell me these I would be hugely grateful & it would help get the old thing back on the road.
Front to rear hydraulic pipes
greenstuff
- My Cars: 1965 Citroen Ami 6 Break
Re: Front to rear hydraulic pipes
Try Pleiades in Sawtry Cambs they can make them to exact length 01487831239 Martin is the man to speak to, they do mail order too.
greenstuff
I'll ring him in the morning, cheers. Will let you know how I get on!
greenstuff
Well, that was painless - £90 and there's a set in the post!
jamescarruthers
- x 39
Yes, Martin is very good!!!
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
greenstuff
Belated update - after getting these pipes made up the garage got cold feet and told me to take the car away! This worked out better in the end, though, because then I found out that there was a Citroen specialist nearby (M&M in Holmebridge) and they did the re-pipe and the height corrector, fixed the handbrake, replaced the ailing accumulator sphere and the brake pipe that ruptured when they re-pressurised it after completing all the other work! They even welded a new exhaust hanger pin thing onto the rear crossmember where I'd deployed a bungee cord some time ago
Good lads and a job well done.
panky
'88 BX GTi (a long time ago) - x 172
Great to hear some positive feedback about a garage
usually just the bad stuff gets back.
