"All We Need is Radio Goo-goo ..Radio GaGa"
Gareth Wales
Post by Gareth Wales »
Could anyone decipher some control labels on my Aiwa CT-R429M PLL Synthesized Tuner car radio. What does A.ME/DISP and DRV mean. It also calls itself a CD Changer Control, but momently, it will only play tapes.
Finally RDS - EON ? I haven't a clue.
Is it possible to get the users manual on-line, I wonder.
Gareth
x 103
closest manual i can find to yours is;
http://www.eu.aiwa.com/en/pdf/manuals/CT-R154.pdf
the 'CD CHanger Control' means if you could find a suitable Aiwa CD Changer then you have a 1 in 10 chance of getting the bugger to work correctly with the head unit and play CD's! However i doubt you'll be that lucky and will be stuck with tapes :(
RDS is Radio Display System, it means that along with the audio that is send through the wireless, a little piece of information is included which tells the player what the name of the radio station is, it then displays this information on your head unit display!
Have a look in that manual for some of the other meanings!
Dunno about the first bit but RDS-EON stands for (deep breath)
Radio Data System - Enhanced Other Networks.
RDS gives you text on the display & search facilities, EON allows traffic news etc from other stations to the one you are listening to interrupt and to be switched to you for the duration of that news.
Gareth Wales
Multi-thanks guys. I think the UN weapons inspectorate should be diverted from Iran to look into this.
You're proably right, Vanny, I'll stick to tapes - after all I bought Petula Clark's Sixties Hits for only 10p.
Stewart (oily!)
Post by Stewart (oily!) »
I have an AIWA stereo with the CD changer controls on it too, it never came with a manual, there was supposed to be a downloadable one for it but the link didnt work :? I am currently popping the face off to switch it on/off, it does have a walkman jack though which works a treat.
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
Gareth Wales
Stewart
I switch mine off by keeping my finger pressed on the MUTE button until it says Goodbye :P
Gareth
sleepy0905
Post by sleepy0905 »
Gareth I have the manual i will find it on disk and email it too you as mine is the same stereo.
Gareth i have sent you the manual by email if you need any more help just ask I also have the circuit diagram if you need it and its fitting instructions.
Gareth Wales
Many thanks Aaron - the manual is excellent - my radio can even tell the time.
Gareth
sleepy0905
No problem, I bought mine of ebay but i had to replace the power amp ic but that was nice and easy even though it was a surface mount chip, the replacement chip only cost £10.
Pleased i could help :D
Stewart (oily!)
I pressed my mute button, and it stopped, said gooodbye too :) I will check the model number, think i would like a copy of the manual sleepy
Stewart
sleepy0905
Hi stewart my manual covers models CTR429M , CTR419 , CTR409 you can have a copy if you want it is no problem.
Stewart (oily!)
Thanks sleepy, just looking at mine now, its a CT R430M, I did find a non working link for a PDF manual when I bought it so if you could send me a copy of the manual I think it might be worth having.
Stewart
sleepy0905
No probs email sent. :D
