Skimming XUD9 diesel cylinder head
Dyane425
I am considering getting my cylinder head skimmed. Quite a few firms do this, but they advise that on many Diesels, the valves sit proud of the surface of the head, and will need to be removed prior to skimming. Do the valves sit proud of the surface of the head on the XUD 9 (D9B) Diesel engine (1991 J reg Diesel Auto)?
Kaapelimies
- x 16
Re: Skimming XUD9 diesel cylinder head
Strange question. I've always had the head checked for leaks, which means it has to be totally dismantled. I would never skim a head without checking it's trouble free. It doesn't even cost so much compared to doing all the work and after the first 1000km find out that the head is cracked.
As Kap says skimming the head just for the sake of it is pretty pointless unless it's warped from over-heating in which case it's most likely the end of your engine. Any decent engineering company should be able to check tolerances and remove components like valves etc before skimming and prob a good idea to lap the valves as well, sounds as though youre having problems.
I'm pretty sure an early pug 306 n,/a head is the same? And easier to source if yours is knackered.
There maybe 2 variations 66hp and 72hp round port and square port if my memory is correct.
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
With a cast block and alloy head the rates of expansion and contraction of the two halves will result in warping, within the micrometer range. Obviously this is why you've got a gasket.
I've always been taught with an XUD when the head gasket let's go, the head will have some amount of warp and should be skimmed not needs be to make it seal but to give the next headgasket the longest life. And XUD typically can't be skimmed more than 3 times.
On the bottom of the head there should be a circular depression, this tells you how many times the head has been skimmed (as it gets skimmed the bottom of the depression becomes shallower).
A decent engineering company will tell you if it needs taking apart or not. Most places will strip it down as part of the pre and post cleaning process. I wouldn't bother to do it yourself unless your curious of really tight on money. There are a couple of types of valve spring compressor, make sure you get the right one. My diesel one won't work on the valver head.
