For sale
x 138
For sale
Post by rutter123 »
Not bx related.
I have for sale a new reconditioned diesel injector (1 only) for a Citroen Relay 2008 model fitted with the Ford 2.2 tdci, I think they call it the Puma lump (120ps), also relates to the Peugeot Boxer, Fiat Ducato, and I'm sure some other derivatives, I believe from 2007/2014
Was brought in error as I later found out it was a hole in the piston, tho the fault code showed up as injector issue on that cylinder, (AA)
The item is a genuine Factory recon by Denso and it is the piezoelectric type, it has the factory code with it but the bag has been opened so cannot be returned, I paid just shy of £300 for it .
Sensible offers if anyone knows anyone who might need it or needs any more info.
Re: For sale
I'm pretty sure the Puma lump was never fitted in any PSA vehicles. They did do a 2.2 version of the Puma, but it was replaced eventually with the 2.2 DW12 lump.
Just in case someone sees the 'Puma' bit and doesn't go through with asking you about it :)
x 138
Re: For sale
Post by rutter123 »
Thanks for that Kitch, I was a little unsure, I brought the injector on the chassis number and reg, DW12 sounds familiar.
x 138
Re: For sale
Post by rutter123 »
P22DTE (4HV)
P8FA
P8FB
QVFA
QVFB
PUMA 22 DT
Are amongst many engine types fitted from 2007/2012 in the Relay,/Boxer according to Googly search
Who knows??
Re: For sale
The Puma lump was the twin-cam, chain driven version used in the Transit from 2006 onwards, and the mk3 Mondeo. When the newer Transit came out, along with the mk4 Mondeo, they were PSA-powered. Pretty sure your injector will be one of those (which is good, as it fits more vehicles) rather than the Puma one. All this is off the top of my head though!
