1991 Tzd estate, last on road 5 years ago, been stored under cover, 205k,
Unfortunately started it up to move and a hydraulic leak appeared near rear, wheel,drivers side.
Good points,
Engine despite miles is very good , very smooth, no head gasket issues, tho suffers from turbo lag, tho possibly pump needs turning up?
Has a set of ok 16v /Gti Alloy wheels (5.5 width )
16v steering wheel,
Air Con, fairly rare?
Good body, underneath as I remember
Interior good,
Currently on steel wheels with worn snow tyres,
Bad Points,
Hydraulic leak!
Radius arms need doing
2nd gear synrcho iffy,
Fault on drivers window regulator,(tho window stays up)
Speedo doesn't work, tho only stopped recently so miles accurate.
Car comes with spares from previous BX including a new wing, bumper, rear lights, alternator a few more etc.Alloys as described.
No battery but can provide one for start up etc( have to remove hydraulic pump belt )
Car will need trailer to remove, maybe possible to deliver at cost if not too far,car is near Buxton, Derbyshire
£300,
Jason (NUMBER DELETED FOR SECURITY)
Photos hopefully later
Jason 07983 997253
Bx TD Estate , Air con,1991, project
Jatoc
Izaak
- My Cars: BX TZD 1.7 Turbo Hatch
BX TGD 1.7 Hatch - x 2
Re: Bx TD Estate , Air con,1991, project
Tried to call you. Which engine ?
The ad says TD and the intercooler is prob a bit of a hint.Should be nicely run in at that mileage.
DELETED.
festus19
- My Cars: Jaguar x type but I'm looking for a nd project hope this is allowed
Hi have you still got the bx?
