Hi All,
Been chasing leeking hyd oil, and seam to be a return pipe on the under side, manged to get it out by pulling engine forward to sort but have found oil in the foot well is this from the return pipe or is the unit at fault in side?
Thank you.
Brake douser leeks!
- x 117
Re: Brake douser leeks!
That return pipe is a common failure. its very difficult to get off as well as you have found out. Its unlikely to be another leak as well on the doseur as the LHM just tracks back inside the car and soaks into the felt under the carpet. Messy.
womble3go
I was not sure it seam to coming out the middle were pedal pushes though.
xantia_v6
- My Cars: Peugeot 308 CC
Citroen XM V6 ES9
Citroen Xantia V6
Jaguar XJ-S V12 - x 72
The rubber cap on the brake valve commonly leaks, the brake valve is the same on all hydraulic Citroens form DS to Xantia.
See: https://frenchcarforum.co.uk/forum/view ... 50#p446049
womble3go
Thank you for that, I will put in the other one that I have will try and a new seal so its ready to go next time.
Kevin.
Kevin.
