Hi any ideas? No noise at all! Thanks
Brian
Rear wiper not working
Cromerbrian
- My Cars: Citroen ds,ax,visa,bx
NeilGP
- x 3
Re: Rear wiper not working
Have you been doing work under the dash on the offside?
I had a similar issue and it turn out to be a wiring connection that had been pulled whrn I was checking my Alarm wiring.
Also check the relay that also controls the self park
Neil
A476 RBX
Series 1 BX 16TRS
A476 RBX
Series 1 BX 16TRS
Doesn't the rear wiper rely on a switched earth? Could be a broken wire in the rubber boot between body and tailgate.
BX 14 GT
- My Cars: 1990 Citroen BX 14 TGE berline (1 series and 2 series BX hybrid)
Hi Brian,
do you have a first or a second series BX? First series BX had a rely for the rear wiper, the second seeies BX hadn't ! In both cases, have you cecked your rear wiper switch? Maybe It's just connection failure...
