Rear seatbelt anchor bolt (the one under back seat) just one bolt that's all
Thanx
wanted
wanted
Meter rat
- My Cars: Citroen Acadiane
Citroen BX 16 TGS
The moderns.
Skoda Superb
Citroen C1
The Motor Bike,
250 MZ - x 20
Re: wanted
I should be able to get one from the scrap car in Derby, by the end of the week. If this is any help?
Re: wanted
Yes please if you can that would be good.
Meter rat
Citroen BX 16 TGS
The moderns.
Skoda Superb
Citroen C1
The Motor Bike,
250 MZ - x 20
Re: wanted
Can you confirm the size, I presume 19mm? And a photo of which bolt and its location?
Re: wanted
All the rear anchor bolts are tthe same but specifically the one I need fixes the middle lap belt and a single stalk, you will need to tip the rear seat up to gain access they are 17mm head, only use a 6 pointed socket as a 12 point may slip and round it off, they will be f tight.
Meter rat
Citroen BX 16 TGS
The moderns.
Skoda Superb
Citroen C1
The Motor Bike,
250 MZ - x 20
Re: wanted
Went in today, started to remove the bolt, but I think it has spun underneath. I got one of the side bolts that hold the bottom side seat belt anchor. If this is not suitable I’ll go back tomorrow or Saturday with a breaker bar and have another go for you.
Re: wanted
Yeah that's fine all the lower anchor bolts are the same so that will do nicely, the middle ones can be tight as the ends of the threads are exposed on the underside of the floor, would you stick it in the post?
Meter rat
Citroen BX 16 TGS
The moderns.
Skoda Superb
Citroen C1
The Motor Bike,
250 MZ - x 20
Re: wanted
Pm me your details, and I can post.
Meter rat
Citroen BX 16 TGS
The moderns.
Skoda Superb
Citroen C1
The Motor Bike,
250 MZ - x 20
Re: wanted
Did this arrive?
Re: wanted
Yes it did I have pm'd you how much do I owe you. Thanx
Meter rat
Citroen BX 16 TGS
The moderns.
Skoda Superb
Citroen C1
The Motor Bike,
250 MZ - x 20
Re: wanted
Don’t worry. It didn’t exlacty break the bank.
Re: wanted
Thanx for that
