mk 1 16v fuel pressure regulator
mac1776
My Cars: Bx 16v, Riley Elf, Volvo V60 D5, Clio 200 Sport
Post by mac1776 »
Hi All,
I bought a used regulator only to find it is corroded on the casing and is leaking fuel, not ideal.
If anyone has a good one leaking in their shed/loft please let me know
Many thanks
Mac
x 138
Re: mk 1 16v fuel pressure regulator
Post by rutter123 »
Try googling any part numbers you can see on it, usually gets results
Don't think Another s/h one is a good Idea I suspect after 30 odd years a lot of them will be on their last legs
mac1776
Post by mac1776 »
Good call, thank you. I will have a look
jamescarruthers
x 37
Post by jamescarruthers »
Can you use an aftermarket one if you don't have any luck? For example Malpassi (who are known mainly for low pressure carburettor regulators) probably do an adjustable one for the high pressure required in a fuel injection system.
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
x 138
Post by rutter123 »
If its a Bosch unit you'll prob find they are still available new from Bosch direct. They are a fairly standard thing so sourcing one shouldn't be too hard.
