Wanted 16v injector plug & cable
I just need the plug which attaches to the injector & the cable attached to it, i don't need all 4, i just need one in order to clean my injectors, although if you've got all 4 plugs with the wiring intact, that would be fine as well.
- x 60
Re: Wanted 16v injector plug & cable
When I wanted to temporarily connect a circuit on my BX, (to a plug the size of the petrol injectors) I used the plugs out of an old kettle and connected them to the relevant circuit. I know that it's a long shot as the plugs can be many sizes, but it may be worth a try?
Hope that helps.
Hope that helps.
Cracking idea David, i'll give it a go
