ABS
tim leech
ABS
Post by tim leech »
Just noticed the ABS light doesnt work on my new 16v, it was problematical back in 1999 when I sold it. Could just be the bilb or its been disconnected for a reason.
I has both rear wheels sensors replaced when I previously owned it and it was £250 then!
Is it hard to fix and is it expensive?
Eeek! :shock:
M
Post by M »
My thoughts are the bulb has either failed or has been disconnected.
Measuring the resistance at the ABS ecu for each of the sensors will show if there is a problem with a sensor - a continuity check will show if the wiring is damaged.
Lets hope no one has done the trick that dogged Jon's burgundy BX with its "ABS light just come on" problem :roll:
What trick's that Marty? I have a light on problem at the moment and am considering all possiblilities and will tackle them in order of probability.
If memory serves, wasn't this the car that was sold as "ABS light comes on sometimes"
and it was actually "ABS lamp permanently on due to some muppet fitting a non-ABS rear arm, and just hacking the sensor off"
Seller's descriptions. You just gotta love 'em.
Well I don't think that's high up on my list of probabilities! :D
Cornishbx16v
Post by Cornishbx16v »
would start with the bulb! simple things! may have had the bulb removed for mot????
Timmo.
After all I AM CORNISH!!!!
www.bx16v.com
www.bx16v.co.uk/forum
www.bx16valve.co.uk
I agree with Cornish - check the bulb first. Remember when all is working correctly it should come on then go out when its done its test. (in fact my TD tests when I turn it on to heat it and again when the engine has started.) this means that nothing at all is happening - as a sensor or other fault should leave the light ON.
With care you should be able to remove the bulb holder without removing the dash panel - by reaching up through the switch panel - then you'll know why mechanics who work on French cars charge so much - as they have extra joints in their hands.
Re: ABS
tim leech wrote:Just noticed the ABS light doesnt work on my new 16v, it was problematical back in 1999 when I sold it. Could just be the bilb or its been disconnected for a reason.
Might be a good idea to check if the ABS is working before looking at the bulb. Find a deserted, safe piece of road and apply the brakes hard at 30mph! If you hear the ratchetty noise and you stop in a straight line then it is a good indication. :) Do it on a wet road and you stop straight even better. :D But beware of testing it on wet road with substantial surface water cos the ABS cannot compensate for aquaplaning! :shock:
tim leech
Post by tim leech »
Thanks guys will do, am taking the dash pod out tomorrow weather permitting to replace most of the dahs bulbs that have broken! The previous owner was a mechanic so am hoping its in good order.
Cornishbx16v
an easier way to test the sensors is to use a multimeter throught he abs loom! if ones dead then its easy enough to swap! and then piut the bulb back in!
Timmo.
www.bx16v.com
www.bx16valve.co.uk
Toddman
ABS
Post by Toddman »
My money says you have a failed ABS sensor or as often the case a broken wire leading to it.
The bulb will most likely have been removed or the wiring to it just unplugged from the loom located just behind the dash clock set.
I would sort the bulb out and then chances are it will be on all the time which is a good sign that a sensor has failed so a quick check with a meter will tell you which one.
2nd hand sensors are a good way of saving money and I am in the middle of breaking a 16v so might be able to help out.
Luke
Please call me Luke :)
http://www.bx16valve.com
tim leech
Post by tim leech »
Thanks luke, i need a pair of foglamps for 16v if you have some? Mine are nasty halfords ones and one of them is broken!
Toddman
fogs
Post by Toddman »
Will do my best Tim.
The bumper has been reserved but hopefully the chap will not need the fogs but I will find out and let youu know.
Luke
tim leech
Post by tim leech »
Thanks matey.
