Sorted
Fitted the FAE 79156 from Mister Auto today, and the tacho now works as it should.
The item came boxed in an EFI-Bougicord carton, coded 79156F, correct dimensions, lead, connector etc etc.
d.c.resistance is 71R, in case anyone needs to check theirs; my old one had gone open-circuit.
Getting to the little bugger was a bit involved, as it was completely invisible, despite lights and mirrors.
Resorted to unbolting the hydraulic pump and its alu mounting block, and moving the pump aside.
This allowed the sensor to be seen, and unclamped.
Some ham-fisted 'erbert had, at some point, replaced the HPP pump, but made a right pig's ear of the cabling in that area, unnecessarily tangling and mis-routing speedo cable, sensor cable, throttle cable, etc., all of which is now sorted. Only the clutch cable took a sensible path. Hoping for a steadier speedo needle when the car gets on the road!
Handbrake cables
Yesterday replaced the handbrake cables with new. Old ones hopelessly stiff, although without any external wear.
Pushed a quantity of 5W30 down the new cables before fitting them.
Haynes' recommendation to stand on the footbrake to allow the handbrake self-adjust to operate worked out well.
Starter relay
Tomorrow, aiming to fit a relay between IGN sw and starter solenoid, to take the load off the IGN sw.
Will likely mount next to the glow-plug relay, and divert the existing trigger cable to the relay coil.
Radio/CD
Original door speakers pooped, so will replace with Pyle PDMW5.
Dash piezo tweeters have arrived, and have made up a pair of crossovers.
Will post some photos when the audio is all sorted.
Sony radio/cd HU is on the Xmas wishlist.
