BX parts: 8v GTi, 1.9D & 1.7TD
monkeyfeet
I'm doing another round of clearing my garage out and have unearthed several boxes of spares that I'd collected over the years of BX ownership.
There's a bit of a mix of parts and I'll list each item individually with more details and post pictures where I can., but for the meantime:
From the top of my head (and maybe with a bit of help from some photos )
Front struts
Headlights - 1 or two pairs, tail-lights 2 pairs ("clear" and later "smoked types")
Hydraulic pump
Reservoir
Height adjuster
GTi inlet manifold (with injectors)
1.9D (probably) plastic inlet manifold / plenum (?)
CV & drive shaft
Starter motor. Bosch 1006 821 131
Diesel pump (1.9D?)
1.9D Exhaust sections
1.7TD Radiator fans
Instrument console (speedo /rev etc)
OE scissor jacks
Assorted interior trim parts
Door lock solenoids
And quite possibly several other parts that I'll add on as I can.
I'll put the pictures on here / FCF and market place and post the links, probably the easiest way.
Pleased to answer any enquiries to put donor car type against the unidentified items.
(please also note that I'm not at home for a couple of days yet and I work away so please bear with me)
Thanks for now.
Front struts
Hydraulic pump
Reservoir
Height adjuster
CV & drive shaft
Diesel pump (1.9D?)
1.7TD Radiator fans
OE scissor jacks
Door lock solenoids
Thanks for now.
Re: BX parts: 8v GTi, 1.9D & 1.7TD
Thank you for listing these but could I ask that you please put a price per items or collectively as as per forum terms.
Thanks
Thanks
monkeyfeet
Hi Tim,
Sorry about that, it was meant to be more of a summary / notification than an ad.
Had to travel away for a while for work, intention is when I get back I'll list items individually with pictures & prices.
Some pictures on Market place, I'll put up the links as soon as.
Thanks for ypur patience!
david troughton
Hi
Do you still have a front strut?
I presume they fit all variants?
What price? I'll pay courier costs in this crazy time.
Best
david
Best
david
Cromerbrian
- My Cars: Citroen ds,ax,visa,bx
Hi you a pair of headlights please thanks brian
Pedigreed
- My Cars: BX Athena 1600
Hi M.,I’m looking for a hazard warning light switch but happy to buy complete panel and switches for 91 BX 1.6 TGS if you have them.
- x 117
This thread started sometime ago - October 2020. Perhaps a PM might get a response.
I have front struts available if the OP does not respond in a week or two.
david troughton
What price your front struts (x1). Inc courier, unless you’re near Stratford-Upon-Avon (CV37).
Best
Best
I've prob got a hazard light switch
- x 117
OK noted. I will pm you after waiting for the OP to respond.david troughton wrote: Sat Feb 20, 2021 11:28 pm What price your front struts (x1). Inc courier, unless you’re near Stratford-Upon-Avon (CV37).
Best
Cromerbrian
Hi have you got a pair of headlights a light unit for the number plate and a hazard warning switch please if so how much would they be please
monkeyfeet
Hi Everyone,
Firstly I'd like to say thanks for your interest.
I do have struts & headlights but I'm afaid due to a family problems I've not been able to get home & catalogue the bits as promised.
I really can't say when I will get home next but its not likely to be for several months yet.
I can only apologise but in the meantime, if you're not in a hury for any of the parts, please post here and I can make contact, ask if the parts are still required etc, later down the line.
Thank you for your patience,
Mark
Mark
monkeyfeet
Hi, I've taken some photos and placed the ads on marketplace:
exhaust boxes:
tail lights:
Headlights (2 pairs left):
GTi MAF units x2:
Loads more available, I'll be adding them on soon.
exhaust boxes:
tail lights:
GTi MAF units x2:
monkeyfeet
Above post was meant to be for the links only....
A pillar left side top internal plastic trim in black if u got one
