Hello,
Is it possible to get a BX for under £500? I understand that if possible it will need work at this price. If anyone has or knows of anything please get it touch.
Thanks,
Cameron.
BX for under £500?
Oldretrocars
- My Cars: Xantia 2.1 TD
Re: BX for under £500?
I'm sure there is still the chance - there's a BX Facebook group which is a little busier than this forum, which may be another avenue.
If Yr after a project and can weld then yes you can they come up on ebay and the usual sites usually been stooda few years, will most likely need a considerable amount of work, depends on your abilities and what you want as an end result
But the answer is yes they are out there, rust is the main thing to look for, bx's can rust where you can't see it.
Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
ZX Volcane keeping others going - x 81
The thing is, it is easy to spend more getting to the point of what you would pay for a car which didn't need the work you had done in the first place. Take a look at the number of projects bought that get started and moved on as a project again. They defeat many due to cost and time and the unexpected. You may be fully aware of what you are taking on but in case you are not, think it over seriously.
