Heater fan stuck on
RobC
My Cars: 1991 Citroen BX 16v
x 30
Heater fan stuck on
Post by RobC »
Before I start pulling the dash apart, just wanted to double check if anyone could advise if the fault lies elsewhere (eg in the scuttle ?)
Symptoms:
- as soon as you touch the dial the heater fan is stuck permanently at semi-full speed (ie max on the dial without the full speed relay).
- full speed relay still works as normal and toggles on/off and takes the fans ‘up to 11’
- turning the ignition off and on again cuts the fan, but if you turn the dial again it comes on nearly-full speed and the dial does nothing again (apart from the full speed relay still working properly, as above)
Rob
1991 Citroen BX 16v
Re: Heater fan stuck on
Could it be the resistor pack? I can't think how it would prevent you from switching it off again, but stranger things have happened. Can only be that or the control panel.
RobC
x 30
Post by RobC »
Cheer Kitch- is that the little box of tricks attached to the fan itself?
1991 Citroen BX 16v
RobC
x 30
Post by RobC »
Aha, this post from the archive implies I have a failed transistor due to the symptoms being permanent ‘on’:
https://www.bxclub.co.uk/forum/viewtopi ... 3d468d4935
1991 Citroen BX 16v
My Cars: BX GTi, C3 Auto
x 113
It can be just corrosion under the earth contact strip. You will see what I mean when it in your hand. This is a GOOD fault in the winter time, much better than it failing to turn on at all.
RobC wrote: Mon Dec 07, 2020 10:37 pm Cheer Kitch- is that the little box of tricks attached to the fan itself?
Mounted inside the fan motor housing, yeah.
RobC wrote: Tue Dec 08, 2020 1:48 pm Aha, this post from the archive implies I have a failed transistor due to the symptoms being permanent ‘on’:
Ah, so it's a part of the resistor pack?
RobC
x 30
Post by RobC »
If I’m reading the old tech post (and circuit diagram) correctly I don’t think there are any resistors- it’s a transistor inside the fan housing.
/pedantmode
1991 Citroen BX 16v
white exec
My Cars: 1992 BX19D Millesime
- LHD, NA, AC, RP_5800
1996 XM 2.5TD Exclusive
x 73
Post by white exec »
Iirc, originally a module with a single (Darlington) power transistor, mounted on a metal heatsink.
Originally located in the heater/steering column area, but later moved to the blower (scuttle) area, for improved airflow cooling. Suffers from exposure to weather.
x 138
Post by rutter123 »
Then disintegrates into dust.
They are still available new but quite pricey.
I'm sure someone in the know could make a replacement with a few components.
