Have just found that the rear centre seat belt consists only of the short part with the socket/release, and nothing else.
Would have expected at least a lap strap too, but it's not there - neither under the cushion nor behind the armrest drape.
Was the 5th belt some kind of optional extra in '92?
Missing seat belt?
- LHD, NA, AC, RP_5800
Missing seat belt?
- x 16
Re: Missing seat belt?
Surely not an option. You did check under the seat by folding it down(up)?
Yes, not there. Three release buckles, but only the two lap+diagonal main belts.
- x 26
I doubt they’d install a release buckle without a belt for it!
Therefore I would suggest it’s been removed rather than being optional.
1991 Citroen BX 16v
Just taken another look, and it's now obvious that the centre long belt has been removed. One of the anchorage bolts has a gap under the head, and is only anchoring one strap instead of two. Will get another belt ordered.
This afternoon's matriculation test should be interesting, for the 5-seater
- My Cars: too many....
- x 125
if it has been split/frayed etc maybe it was removed for MOT purposes? anyway, if its not there they cant test it! as you say easy to replace
Now replaced. Complete new one only €14!
Was a tad concerned about the matriculation (re-plating) test, as it's meant to be exceptionally thorough, and for some reason a seat-belt check on all seats (and this is logged as a 5-seater) is normally done to the letter.
As it turned out, the matric test was anything but thorough - I think a mixture of minor industrial action at the centre, some obvious delight in seeing a BX in Malaga, and seasonal goodwill.
