BX Project
x 103
Re: BX Project
Citroën BX – XPO – Welding Repair of the Scuttle Pt2
At last, the final scuttle repair can begin. This seems like a simple piece to weld in, but for the next panel to align, it needs to be neat.
https://bxproject.co.uk/blog/citroen-bx ... t2-repair/
x 103
Re: BX Project
Citroën BX – XPO – Donor Panel A-Pillar Repair - Eps20
In this article, I tackle an inner A-pillar repair to the donor body panel. Now the Mega Shed is built, I can plough on with the XPO project.
https://bxproject.co.uk/blog/citroen-bx ... ar-repair/
x 103
Re: BX Project
Citroën BX - How To - Door Pillar Repair
Legend has it, that BX doors regularly fall off. They don't, but it's often close. Let's tackle a Citroen BX door pillar repair, and keep that door firmly fixed to the car!
panky
'88 BX GTi (a long time ago)
x 143
Re: BX Project
Post by panky »
Another great write up and skilfully done repair
Image Image ImageImage
x 103
Re: BX Project
Thank Panky, I can't say I'm 100% happy with it as it was a tad rushed. It reportedly wouldn't fit quite right at the other end either, which is annoying as it fit the panel I took it off just fine. Never mind, practice makes perfect!
panky
x 143
Re: BX Project
Post by panky »
Your work was fine Mr 27 just had a bent BX :wink:
deltic
x 49
Re: BX Project
Post by deltic »
I’m in awe of the sheer amount of skill to do this!
2016 Volvo V40 T2 R-Design Pro, blue, 34,000 miles
x 103
Re: BX Project
Citroen BX - FotU 2022 Prep - Fuel Leak
Before I set off to this year's Festival of the Unexceptional, I wanted to trace a fluid leak near the engine. But first, the Citroen BX had a rather major fuel leak! Amazed I even made it.
https://bxproject.co.uk/blog/citroen-bx ... fuel-leak/
x 174
Re: BX Project
One year you'll get there without any drama..... good to see you Vanny though!
x 103
Re: BX Project
Tim Leech wrote: Mon Aug 01, 2022 10:40 am One year you'll get there without any drama..... good to see you Vanny though!
Oh, this was nothing compared to what happened next!
x 103
Re: BX Project
Citroën BX - FotU 2022 Prep - More Leaks
SPOILER ALERT - I did make it to #FotU last weekend, but it was very touch and go. By 7pm on the Friday before the engine bay content was all over the drive. Enjoy this tale of, erm, miss adventure . . .
https://bxproject.co.uk/blog/citroen-bx ... ore-leaks/
x 103
Re: BX Project
Car Show - FotU 2022 - My Highlights
After weeks of turmoil with the BX, I wondered if it would even make it to FotU 22. But it did, and the festival was fantastic. After a few weeks' delay, finally, I can regale you with my show experience!
#FotU #CitroenBX
https://bxproject.co.uk/blog/car-show-f ... ighlights/
saintjamesy89
My Cars: 1985 Citroen BX19 GT
198x Citroen BX16 TRS auto
1991 Saab 900 16v convertible
2007 Lexus RX 400h SE
x 156
Re: BX Project
Post by saintjamesy89 »
Some awesome content here Vanny, a superblog!
2006 Lexus RX 400h SE hybrid
x 103
Re: BX Project
saintjamesy89 wrote: Mon Aug 29, 2022 9:42 am Some awesome content here Vanny, a superblog!
Cheers, it's probably too many words for most people, but makes a very nice change from mind-numbing technical reports.
I've been following your blogged adventures too, sounds like a lot of work going on!
panky
x 143
Re: BX Project
Post by panky »
Just got around to reading your report, good work and brought back memories of C&T Garage and MOT failures :D
