citroen bx4x4 gti
andrewj1967
My Cars: citroen bx 4x4 gti renault 16tx mg montego turbo
citroen bx4x4 gti
Post by andrewj1967 »
hi dose anybody now where i can get abs sensors for the rear subframe of my 4x4 thanks andrew
senmathal
My Cars: Citroen BX 16 Valve 89, Citroen C5 HDI 163 -12
Re: citroen bx4x4 gti
Post by senmathal »
I don´t think they are available longer. The way to go is to use ABS sensors for Xantia. The problem is that the connectors under the rear seats did not fit. You have to modify this in any way.
/Mats
white exec
My Cars: 1992 BX19D Millesime
- LHD, NA, AC, RP_5800
1996 XM 2.5TD Exclusive
x 73
Post by white exec »
From Parts, the ABS ECU ('calculator') is the same for both 4x4 and 4x2 cars, so likely that the 4x4 sensors are electrically the same too.
OE part numbers are as follows, if any help...
4x4 rear, left 96 016 397
4x4 rear, right 96 019 964
4x2 rear, both sides 91 537 913
ABS calculator (ECU) 91 537 759
All NFP, but numbers might help in looking for alternatives.
If dimensions are ok, and d.c. resistance matches up, a substitute should work.
d.c. resistance of 1050ohm has been a common value, but there are others.
x 116
I think the 4x4 ones are a slightly different design due to the different rear hubs. Usually but not always they fail due to an internal break in the wiring where it flexes and as such can be repaired with a cable splice of some sort.
