Glue or something for rear quarter panel-
senmathal
My Cars: Citroen BX 16 Valve 89, Citroen C5 HDI 163 -12
Post by senmathal »
Hello!
I on my way to replace a rear quarter panel and wonder what type of glue to use between the outer an inner panel? Original there was a thick layer of red foam similar glue. It has to build up a realy thick layer to tighten a gap between the panels.
/Mats
white exec
My Cars: 1992 BX19D Millesime
- LHD, NA, AC, RP_5800
1996 XM 2.5TD Exclusive
x 73
Re: Glue or something for rear quarter panel-
Post by white exec »
Use a few hefty dollops of polyurethane adhesive for a lasting seal, or silicone sealant for something more removable.
Either will bridge a gap, as the dollop flattens.
x 138
Post by rutter123 »
Sikaflex
white exec
x 73
Good stuff.
x 138
Post by rutter123 »
Just a shame Citroen didn't use it (or enough of it) otherwise there would be a few more bx's surviving.
senmathal
Post by senmathal »
Sorry for late respond and thanks for your answer and tip. I think some kind of Sikaflex is a god Solution. I think there will bee a little gap to fill.
Here is a tread of my restoration in a forum. It´s in Swedish but you can maybe look at the pictures :) https://citroenakuten.com/viewtopic.php ... 8&start=15 The car did not has so much rust on the other panels but as you can see in under there is rust and rust and more rust. But this Valver has in original leather seats, AC and sunroof so for me it´s worth the job to restore it. The engine and gearbox is happily in good condition.
/Mats
