JBL sub bass pro sl2 thoughts
Pcheaven
My Cars: Landrover discovery sport 2020
Previously ipace/discovery 5/velar and many others including 2 bx gti back in early 1990
x 12
Post by Pcheaven »
I am considering getting one of these
Has anyone used one - what’s your experience?
Hopefully it will fit under the front seats. Will measure when home Monday
Yes I know speaker cabs which are large perform better. However I don’t want anything in the boot.
I did that in the 90’s with a custom jbl case and 4x18’s on a push pull setup. Great. But mad
Trying to get a great sound without cutting any holes or adding boxes.
ToDo list.
Have a GnT
Have a GnT
3. Adjust the clutch
Have a GnT
Have a GnT
Have a GnT
6. Replace rear spheres
Have a GnT
7. Replace bottom hose
x 116
Re: JBL sub bass pro sl2 thoughts
I have done this on a couple of my BXs under the passenger seat. I used this one: Clarion SRV 313 Powered Subwoofer,
It certainly provides a lot more sound and bass. The bass is not subtle it thumps away quite nicely but is very one note. Bert Jansch sounds much like Lemmie but its great sometimes to just bop along with it all.
jamescarruthers
x 39
Post by jamescarruthers »
Certainly a good idea. I would personally be replacing the original speakers, if you haven’t already, and adding sound deadening first before adding an under seat sub.
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Pcheaven
x 12
Post by Pcheaven »
jamescarruthers wrote: Sun May 09, 2021 5:38 pm Certainly a good idea. I would personally be replacing the original speakers, if you haven’t already, and adding sound deadening first before adding an under seat sub.
New door speakers and new tweeters are on the way.
I may replace the white foam insulation behind the door cards with something more modern and effective.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
