My BX14 RE- Sold.
- LHD, NA, AC, RP_5800
- My Cars: Citroën C4 Grand Picasso
Previous cars
Peugeot 806 TD
Peugeot 309 TD
Ford Fiesta 1.1
Mazda 323 mk1
Nissan Micra mk1 - x 2
Re: My BX14 RE
I live in Tonbridge. Its great to know that there are some BX's so close!
- My Cars: Citroen BX14 RE
Nissan Micra Shape - x 31
Re: My BX14 RE
Very nice! Mk.1 Micra too!Warren Nel wrote: Sat May 29, 2021 11:33 pm I live in Tonbridge. Its great to know that there are some BX's so close!
Re: My BX14 RE
Yay.
I'll link to the write up when I make it tomorrow. I'm now tired.
Re: My BX14 RE
Nicely staged improvements, which show the cumulative effect of getting rid of those voltage drops.
A case of before...and after...and after...and after!
Well done in seeing all that through, and methodically.
She's looking good.
She's looking good.
Re: My BX14 RE
This happened:
https://autoshite.com/topic/36188-fumbl ... 06665_menu
Full write-up of both yesterday's and today's happenings below:https://autoshite.com/topic/36188-fumbl ... 06665_menu
Re: My BX14 RE
I'm having trouble starting the car from warm if I leave it for a few minutes, what could be the issue here?
Re: My BX14 RE
Is that heated intake air needed in warm weather?
Apart from very cold weather (carb icing etc to be avoided), most engines work best with cool, dense air - so pre-heating from a hot exhaust manifold wouldn't help.
Re: My BX14 RE
does it have manual changeover for heated and non heated air intake, for use in the colder months?
ToDo list.
Have a GnT
Have a GnT
3. Adjust the clutch
Have a GnT
Have a GnT
Have a GnT
6. Replace rear spheres
Have a GnT
7. Replace bottom hose
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
- x 28
Re: My BX14 RE
Yes, the 14 has a little lever just visible at the right of that pic under the cable.
My hot starting issues with my old 14 turned out to be an ageing ignition module by the way. Not saying that’s the problem! But something to consider.
1991 Citroen BX 16v
Re: My BX14 RE
I replaced mine yesterday. Their placement being directly opposite to the thermostat housing is just award-winning for automotive stupidity.RobC wrote: Tue Jun 01, 2021 11:11 am Yes, the 14 has a little lever just visible at the right of that pic under the cable.
The starting from hot was just the beginning. It cranks for ever when cold and puts up the same fight after you let it sit after 30 minutes or so.
Things I need to look at are:
- The fuel bowl float position
- The coil, as it's the original and is old
- Potential vacuum leaks
Re: My BX14 RE
Oh, the intake is designed for this, there are notches in the air baffle (where the silver pipe connects to the intake) for above 25 degree weather, between 5-25 degree weather and below freezing. The reason why this is so is because of emissions control IIRC.white exec wrote: Tue Jun 01, 2021 6:47 am Is that heated intake air needed in warm weather?
Re: My BX14 RE
While on a Zoom meeting with some Autoshite members, the fault seems to be down to the wrong size ball valve and float in the float bowl not being able to admit enough fuel for the engine. I can certainly change over the valves from the old carb to the new one, but we'll see if the bowl in the new carb is any different to the old one, as this'll decide whether changing over the float is a viable option.
Re: My BX14 RE
Float bowls were identical, valves and floats swapped over. Car starts up willingly when hot, cold and in between. Result.
I'm not calling it properly fixed, but it's getting there.
https://autoshite.com/topic/36188-fumbl ... nt-2309028
Re: My BX14 RE
Carburettors! Last time I had the pleasures of them was at the very end of the last century. Since then, choice has been decidedly diesel. Not missing the HT and plugs, either. Or the vapour locking. Or the in-tank pumps. Or the mpg.
Hey, ho.
Hey, ho.
