Just discovered that the LHF door's locking does not lock or unlock with the key. Central locking on and off is fine but nothing happens in key mode.
I have a recollection that this is by design but I am 90% sure that this car used to lock with the key.
Anyone confirm or deny this?
Central locking
- x 56
Re: Central locking
Could you be a little more specific on what you're asking here & provide more details?
What model of car do you have? A GTi or TGD for instance?
Does the car have factory fitted remote controlled central locking?
Do you mean that the passenger door isn't unlocking or locking the other locks when you unlock the car from said door, or is the passenger door's lock not operating when unlocked or locked from the drivers side?
If the car has factory fitted remote central locking, then only the drivers door & the remote will control all the locks, the passenger door never will. It's down to the design of the system.
If the car doesn't have factory fitted remote central locking, then you've probably got a fault with the wires or connectors inside the door.
If the central locking isn't controlling the passenger door, then again you've probably got a fault inside the door. It'd probably be corrosion on the connecters inside the passenger door.
Hope that helps.
Hope that helps.
- x 116
Re: Central locking
David do you say that it is normal behaviour for the central locking not to work from the passenger door. I am 100% sure that some of the BXs I have had operate the central locking with the key from both sides but not all of them.
white exec
- LHD, NA, AC, RP_5800
- x 56
Re: Central locking
Yeah, I wasn't very clear on how I explained that. In short, it depends on the setup of the car;Jaba wrote: Tue Jun 08, 2021 12:39 pm David do you say that it is normal behaviour for the central locking not to work from the passenger door. I am 100% sure that some of the BXs I have had operate the central locking with the key from both sides but not all of them.
If the car doesn't have factory fitted remote central locking, then it works from both front doors by default.
If the car does have factory fitted remote central locking, then it only works from the drivers door & the remote control.
That's what I've read somewhere anyway. My BX's central locking, for instance, works from both doors, but it doesn't have a remote control.
In turn, I bought a full set of lock actuators from a GTi a while ago to repair my faulty system, and it only had one 'master' motor, whereas the other three were 'slave' motors. If that's anything to go by, then it would somewhat confirm the theory.
Hope that helps.
Culasse
Re: Central locking
Aha so that is the difference the locking motors.David wrote: Thu Jun 10, 2021 10:59 am
I thought it was something to do with contacts on the lock mechanism. I will have to investigate the circuit diagram and see if that sheds any light as I wouldn't mind modding the locking to work on the passenger door.
