Help I need new nuts.
Meter rat
My Cars: Citroen Acadiane
Citroen BX 16 TGS
The moderns.
Skoda Superb
Citroen C1
The Motor Bike,
250 MZ
x 12
Post by Meter rat »
Can any one help with a set of wheel nuts? I need 12 of them. Since removing the steel wheels and fitting my alloys, I have lost the wheel nuts for the steel wheels. Since the potential purchaser want the steel wheels this could be a problem.
Thank you in advance. Ian
x 43
Re: Help I need new nuts.
Post by David »
Most french cars will have the same nuts, so if you're stuck, go to a local scrap yard, and nearly any that you see will fit. A Peugeot 206, 207, 208, 307 or Citroen C4, Saxo, Picasso etc would be a great place to start. The smller C1 or Peugeot 107, however, use different, smaller nuts, so avoid them.
Hope that helps.
x 136
Post by rutter123 »
I have loads of wheel bolts for standard steel wheels. I can furnish you with 12 or 16.
Kaapelimies
x 16
Post by Kaapelimies »
Wheel nuts for what car? BX has bolts, so surely you haven't lost any nuts ;)
white exec
My Cars: 1992 BX19D Millesime
- LHD, NA, AC, RP_5800
1996 XM 2.5TD Exclusive
x 70
Post by white exec »
The nuts have bolted... :-k
Meter rat
Citroen BX 16 TGS
The moderns.
Skoda Superb
Citroen C1
The Motor Bike,
250 MZ
x 12
Post by Meter rat »
Now sorted thank you. I know, technically they are bolts, but, I need new bolts is a bit Meh. 🤣
