Citroen Parts for sale (mainly GS/A and Dyane)
deltic
x 51
Post by deltic »
Sorry, but only 3 BX rear lights in amongst this lot! But if anyone is interested please get in touch. All used unless otherwise indicated as unused or new. Of course I'm open to reasonable offers. Everything will be available at the National and I will most likely be there on Saturday - look out for a grey BX GTi, J44JHR for which all proceeds will go to keep running...
Millers VSP Lead Substitute x3 £10.00 each
A-Series Parts
Dyane door trim strips (pair) £10.00
Dyane grill muffs x2 £5.00 each
Dyane plastic grill £20.00
Dyane plastic headlamp bezels x2 £5.00 each
Dyane rubber door straps (pair, one starting to crack) £5.00
Hub caps (no fixings) x 8 £5.00 each
Heat exchanger (unused, possibly part number 95548494) £50.00
Coil (untested) £1.00
Wipac oil filter (CA108) £1.00
Fan & (slightly rusty) hub £15.00
DS/ID/SM Parts
Rear Roller Bearing Metal Cap (pair, new, part number
5404563, one in original plastic bag, other has surface rust) £15.00
BX Parts
Rear lights (pair, untinted) £10.00
Rear light (nearside, possibly untinted) £5.00
C4 Parts
Water pump (used for c. 3000 miles) £5.00
GS/A Parts
GSA Speedo cable (new) July 1980 onwards £30.00
GSA speedometer (new) £75.00
Clutch cable (new) (part number QCC1226) £30.00
Sev Marchal distributor cap (new) £20.00
Unidentified S-shaped hydraulic pipe (new) £25.00
Unidentified right and left brackets (new)
(part numbers 5603272 & 5603273) £20.00
Exhaust Y-pipe, 5-speed (new) £45.00
Alloy wheel centre cap x1 £5.00
GSA small hub cap x1 £5.00
GSA fan belt or CX hydraulic pump belt (new but starting to perish?) Free
Oil filter (LS450A) £1.00
GS/GSA rear brake pads (new) Up to June 1981 £5.00
Cibie plastic foglight covers (pair) £20.00
GSA boot struts x 3 £5.00 each
Ducellier coils (untested) x2 £1.00 each
Fuel pump (untested) £10.00
Distributor (untested) £20.00
Weber carburettors x 2 £20.00 each
Brake disc rear (new but with some surface rust) 1 only £5.00
