Peugeot 405 engine
jvbram
- My Cars: Citroen Bx 1.9d, Volvo 360, MB 206, Mitsy L200.
Peugeot 405 engine
Does a Peugeot 405 18 TD engine fit a Citroen Bx TRD?
Kaapelimies
- x 16
Re: Peugeot 405 engine
Yes. It just misses the place for hydraulic pump pulley (in 405 I think there´s a vacuum pump as in Xantia?). I made a thread to a Xantia camshaft, as the size is the same, it just misses a little length and a groove for the key. Just that I haven´t tested yet does it work.. But I don't knoe if you can fit the hydraulic pump around where the pug has the power steering pump?
jvbram
Ok but maybe the Bx camshaft fits the 405 head.
Kaapelimies
- x 16
Yes if you have a donor from BX the cam and cover fits. The main problem is if you snap the timing belt you also snap the cam and a bearing cap or two, so BX cams are getting more and more rare all the time.
jvbram
I know that now!
