Oil gauge
jvbram
- My Cars: Citroen Bx 1.9d, Volvo 360, MB 206, Mitsy L200.
Oil gauge
Is the oil gauge the oil pressure or oil level. Would a low readind, red flashing light, on trd with 450k indicate that its time for a rebuild?
Fumbler
- My Cars: Citroen BX14 RE
Nissan Micra Shape - x 31
Re: Oil gauge
I'm fairly sure it's for oil pressure and if the needle is on the red then either the sensor has broken or you've lost pressure.
Kaapelimies
- x 16
Re: Oil gauge
What model of BX? If it states no "Bar" in the reading, its, just the level. If the low pressure light is flashing, I would measure the oil pressure and if OK just change the sensor. Or just change the sensor if meter not available..
white exec
- LHD, NA, AC, RP_5800
