abs sensor
- x 6
abs sensor
For sale one new front abs sensor, genuine unused, whats it worth?
1993 tzd estate, on sorn
1991 4x4 estate, on the road
- My Cars: BX x 2
Xantia 2.1 Break
Xantia 1.9 Saloon
Xantia HDI Break
Proton (now sold for scrap)
Supra x 2
Audi x 5 (now 4)
XM Break
Re: abs sensor
What are you asking for it? Could be interested at the right price.
- My Cars: BX GTi, C3 Auto
- x 46
Re: abs sensor
This is a rarity and unavailable from anywhere. When available they were around £80 from Citroen so that is your starting point.
- x 6
Re: abs sensor
by citronut » Tue Oct 11, 2011 1:29 pm
99% of the time the wire fractures were it is constantly flexed on rears over the rear arm, and fronts as it goes around the front strut,
they can usualy be repaired if you can find the break,
here is price and part No. from citroen
91539398 SPEED SENSOR 258.09 GBP 309.71 GBP 309.71 GBP
i think they must have trouble with the decimal point point point point
As you can see last price before they became unavailable was £309, i actually bought a rear one from leaders citroen liverpool in 2009 for £170 part no 91537913, so was probably hoping for about £150ish. (sorry not copy and pasted this right, barry)
- LHD, NA, AC, RP_5800
Re: abs sensor
There are a good few new ABS sensors available, which have similar mounting arrangements (cylindrical snout plus fixing arm). For roughly contemporary XM, there were essentially two types used, differing only in their d.c. resistances, one of which was 1050ohm, the other iirc much lower. If we knew the resistance of the BX ones (and some dimensions), we might be able to find a current aftermarket/spare item. The price of this now unobtanium item looks daunting!
As said, the cabling is a minor detail.
- x 26
Re: abs sensor
The resistance for BX sensors is 800-1200 ohms.
A while back (perhaps it will come up in a forum search) there was a discussion about the options available for other sensors that might fit. The wiring will inevitably need to be spliced, as you have already surmised
1991 Citroen BX 16v
- x 46
Re: abs sensor
As I recall only the Peugeot 405 sensor was the same fitting apart from needing a BX connector spliced on.
Re: abs sensor
I have a source of 1050ohm sensors, a VW item. Have one here. Do we know the diameter and reach of the cylindrical body?
- x 6
Re: abs sensor
This is now sold.
- x 46
Re: abs sensor
When I am able to get my hands on my stock I will post some pics and measurements.white exec wrote: ↑Wed Dec 22, 2021 9:25 pmI have a source of 1050ohm sensors, a VW item. Have one here. Do we know the diameter and reach of the cylindrical body?
