Hey all!
So, I am getting ready to rebuild the Solex carburetor in my early 1989 BX 16 TRS. Trouble is, I don't know the exact model of the carburetor. That is why I am asking this here so I don't end up with the wrong rebuild kit.
The engine in the 16 TRS is the XU5 2C with 68/69 kw.
Thanks in advance for your answers!
What carburetor model does the XU5 2C engine have?
Jugostran
- My Cars: 1989 Cimos-Citroën BX 16 TRS
2007 BMW 318d (the "company car") - x 51
Re: What carburetor model does the XU5 2C engine have?
Solex z1 I believe.??
Might be worth double checking.
Fumbler
- My Cars: Citroen BX14 RE
Nissan Micra Shape - x 31
I think it's either a Solex 32/34 Z1 or a Weber 32/34. IIRC Weber models have a tag that's secured by one of the carb lid screws which contains the serial number which you can use to determine jetting and other parameters. I have one going spare.
Canada's only BX
- My Cars: 1990 BX 1.6 5-speed Millesime 110,000 LHD
If it is Solex and the engine is the type 171Z engine, then it could also be the 34-34-Z1 PSA 464. BUT, the factory is well known for making substitutions outside of the regular bill of materials. The 32-34 and 34-34 differ only in the bottom gasket, I am told. The Haynes 1995 book shows illustrations of both Solex and Weber to help ID the unit you have, on pp 365 - 367.
FYI, I know of a BX with Solex carb made during the last production years that is supposed to have had the XU52C installed but its actual motor states it is a BDY - all of which were EFI motors, and so it is impossible, in theory. It is the original engine, BTW, and pretty much exactly as the XU52C anyway.
Jugostran
I have just looked up my rebuild kit, and it seems to be universal for both the 32/34 and 34/34 variants (it comes with gaskets and bits for both). Here is the link;Canada's only BX wrote: Thu Jun 30, 2022 8:57 pm If it is Solex and the engine is the type 171Z engine, then it could also be the 34-34-Z1 PSA 464. BUT, the factory is well known for making substitutions outside of the regular bill of materials. The 32-34 and 34-34 differ only in the bottom gasket, I am told. The Haynes 1995 book shows illustrations of both Solex and Weber to help ID the unit you have, on pp 365 - 367.
https://www.njuskalo.hr/motor-pogonski- ... s-14564323
