BX16 GTi export model wiring/crankshaft sensor
Jori_fin
- My Cars: Citroen BX 16 GTi, 1990, export model
Audi A4 B8 2.0tdi, 2008
Opel Astra 1.6L ecotec, 1996 - x 1
Hey guys! I really hope you could help me, I am in a dead end. I have a bx16 gti 8 valve sohc, the exported model, model year 1990. On the engine, there is a crankshaft position sensor, but I have no place for it to plug in on the main wiring harness/loom. Am I missing a harness or should this model even have a crankshaft position sensor?
I also am having trouble recognizing the ignition system I have. Some sources say it is LU3 jetronic, some say later gtis had motronic and some that it's the magneti marelli. I have the ignition coil on left side firewall, I have a distributor (so I guess it isnt jetronic?), but I cant find MAP sensor or air/fuel mixture from the places they should be according to Haynes. Also the wiring diagrams dont exactly match this car. I have a Bosch ECU 0280000340 under the right side front seat. And there is integrated ECU in the MAF sensor.
Here is a clip on Youtube that I made for you -
Hope you can help me! I am really falling in love in this car, and would like to get running and restored properly.
Cheers, Jori
Cheers, Jori
- x 117
Re: BX16 GTi export model wiring/crankshaft sensor
Quick reply here. There is no crank position sensor on this model with an airflow meter. Crank timing is done by the distributor. That connector you have found is some sort of diagnostic plug and is on all petrol BXs as far as I know. It is never used though.
Since you seem to have a fuel supply problem then a quick test for fuel pump operation, no need for cranking, is that when you turn on the ignition the pump runs for a short time and then stops, this gives fuel pressure at the inlet for starting. Whether this is relay controlled or just ECU controlled I am not sure. So test the fuel pump electrics to see if it is getting any voltage as a first step.
- x 60
I had a lot of trouble getting a 1.9 GTi engine running a few years ago. It looked like there was an harness missing, but eventually I got it running and I put it all in a post on this forum.
The crankshaft position sensor isn't used on this engine, it's only there for diagnostics, so it's not plugged into anything.
That wire that comes out of the bulkhead isn't used either; it connects to the ABS &/or the 4X4 wiring harnesses, if fitted. It looks like your car has neither.
Essentially you need an ignition live and neutral to the coil to work the spark. The distributor works out when it should be sparking, along with the electronic controller or points on the distributor; it has nothing to do with the Ecu.
The fuelling is controlled by the ecu and it has a wire connected to it from the coil to tell it when to open the injectors and let the fuel in, so if you make sure the engine has a spark and then make sure that they're connected together correctly, it should start. If you're unsure, then find my post on here. It's from around 2016. It goes into great detail of what wires connect where, although I was working with a different coil. They all function the same.
Hope that helps.
Hope that helps.
- x 117
Just had a further look at your video and I confirm that there is something amiss as you appear to have two different ignition systems installed. The engine with distributor is used in the earlier GTi before July 1990 and is Jetronic LE3 (according to Haynes). What I assume has happened is that a replacement engine from an earlier car has been installed together with the engine loom and ancillaries for that car.
The later Motronic 3.1 Has a large loom connector that screws on to its counterpart near the alternator that disappears into the front wing and then down to the ECU under the seat. This ECU also controls the fuel pump as well as everything else. A conversion would entail duplicating the functions of this ECU, tricky but not impossible.
You have a challenge on your hands I think. A nice summer time project for you.
Jori_fin
Hey guys! Thanks for the replies, I am loving the support! I was cheering out loud for the first two replies, but the third took me down fast
David - I will look into your post for sure, thank you!
I tested the fuel pump with a separate battery, it works and I get clear fuel to the fuel rail, so the fuel lines are complete with no leaks. So it's not clearly getting voltage from cars own wiring. I ditched all the further plans as I found the crankshaft sensor/diagnostic unplugged, because I was sure (haha
) it would prevent the fuel and ignition systems working properly.
Jaba - are you 100% sure. My video was really messy, I could make a new one or take pics and check for parts that would make it even more clear that there truly is a replacement engine installed. What should I check to make this easier? I guess the engine code would be one the tell it straight away?
Jetronic used a ignition coil located under the intake manifold, am I correct? And mine has the coil on the left side firewall.
The Bosch ECU 0280000340, it was used on a Motronic 3.1.? Jetronic has a different earlier ECU?
Million thanks to you all!
- x 117
So sorry, I misread and assumed you have a 1.9GTi whereas in fact you have the 1.6, presumably monopoint injection. So you have not had an engine transplant and your lack of fuel must be due to some other problem and not engine transplant related.Jori_fin wrote: Sun May 22, 2022 9:34 am
Going back to basics, you say there is no fuel injected. Have you checked that the pump runs while cranking ? If it does then is there a 12v pulse to the injector. Poor connections are common as are broken wires inside the insulation. ECUs can fail as well but they are pretty robust and long lasting.
As this model was not sold in UK I am not up to speed with diagnosing faults. I do have a wiring diagram for a 1.6 Jetronic but this does not show the under the seat ECU and has four injectors so is not much use. I think you have probably got a Motronic system fitted. This site may have some info: https://citroen.tramontana.co.hu/
Additionally the engine was fitted to the Peugeot 206 GTI so there may be more help in that direction.
Once again sorry for the bad info and good luck with getting it going.
Jori_fin
Okay! And no problem, loving the advice you're giving! I have four injectors and a ECU under the seat. If it was Motronic, wouldn't it have TDC sensor providing info to ECU?
There is no pulse to fuel pump, I assumed it was because of the unplugged crankshaft sensor. But as it seems to be just a diagnostic port, I will check the timing, clean all the connectors and ground points, put it all back together and try again. If it's not a success, I will look into replacing relays and sensors one by one.
By the way, where do you get the spare parts from? Is there a dedicated car parts store that would have online shopping available?
Cheers!
BR, Jori
Cheers!
BR, Jori
Jori_fin
Bit of an update!
I put the engine back together, cleaned electrical connectors and grounding points. Now I get fuel to the rail with a proper pressure, I tested spark, I got a bright spark from all the plugs in normal 1-3-4-2 firing order. I when I crank the car, it tries to run (ignition happens). I checked the timing, I assume the timing is ok if I can fit a 10mm drill/pole/whatever, into timing holes on both cam and crankshaft pulley? The engine spins with a hand tool. There is plenty of oil in the engine.
I am thinking I would next drain the oil to see if there are bits of metal or something else alarming. Also I would do compression test for all four cylinders. What else to check?
Haven't had spare hands yet to try to start the car by spraying brake cleaner into intake manifold. I didn't test the injectors when they were off the engine, but I had some gas on the plugs after cranking. If the injectors wouldn't be working properly, what electrical component would be able to cause that? Faulty injector relay?
Edit: I think I will look into your earlier post, David, to make sure injectors are connected properly.
Seems that the injection system is Motronic ML4.1.
xantia_v6
- My Cars: Peugeot 308 CC
Citroen XM V6 ES9
Citroen Xantia V6
Jaguar XJ-S V12 - x 72
Does the ignition have a distributor? If so, you should check that the ignition timing is not 180° out from the valve timing.
Jori_fin
Yes, distributor cap and rotor arm are in correct position.
Edit: got it running with brake cleaner. Next I am going to clean the injectors. If it helps, great - if not, I will be looking into electrical problem.
Edit: cleaned the injectors, seems like a electrical problem. Do the impulses to injectors come from the coil?
Edit: haha
as you have suggested multiple times, I will now make sure the ECU gets the pulse from coil and injectors the pulse from ECU.
Edit: haha
Jori_fin
Some update on this, even though it's not about the title subject anymore. I now have a spray but injectors are running on low voltage, only 8,5V, which is not enough for consistent fuel mist. I guess I am supposed to have 12V on injectors. Fuel pressure is 3bar, I've measured that, so problem doesn't lie there.
Does it work in the way that ground is connected all the time to injectors and ECU fires the injectors with a pulse (connects to the positive terminal)?
I stripped the main harness out and noticed it's not a original, it has some badly made connections (5 wires turned into 1 wire), I guess the loss of voltage is due to that.
If someone has any wiring diagrams for the ECU and injectors, it would be hugely appreciated. I have diagrams from Haynes, but they are no use, there is only Jetronic presented. I have Motronic injection installed.
- x 60
On the GTi that I messed with, the injectors had 12v constantly supplied when the ignition was turned on. I can't remember where the power came from though, but I think it was the ECU. The ECU then pulses the neutral to the injectors every time the distributor sparks, so every half a turn on the engine. All the injectors open together. I don't recall which type of injection system it was either sadly, but it was the 1.9, 8 valve, GTi.
If your voltage seems low, what's the battery like? Has it got plenty of power? If it's weak, then you'll get significant voltage drop.
Hope that helps.
Hope that helps.
I also had poor connections on my ex gti, injector harness had various dry joints, bad earth's, dirty connectors, the Jetronic system needs 12v at the injectors so far as I can remember.
Jori_fin
Hi! Thanks for replies. I get 12,48V out which I take as normal. I got the voltage up to 9,5V by re-doing some connections on the harness. Then I traced the voltage and found out that fuel injector relay (oen 95496621) takes in the 12.4v ish voltage and gives out only 9.5V, so I might have found my weak spot.
But the harness has been fiddled with, some wire routings are really shady, I would love to make sure everything is connected to correct port on ECU. These wiring diagrams are actually pretty close of what I have, I could use this to re-create the harness BUT the quality of pictures are really bad. Would you happen to have the correct manual in hands? (http://bx16valve.com/technical-info/ign ... -16-valve/)
Or is there a place on the forum where different wiring diagrams are stored? Or should I make a separate post about it?
Maybe if you could find a wiring diagram for a Peugeot 205 1.6gti as it uses the same ignition system and engine, poss could give you some guidelines??
Not sure the UK diagrams will cover the 1.6gti as it was not sold here.
