Wanted: parts 96030258, 96046578, 96056235 for BX
todesritter2003
- My Cars: Citroen BX 1.4i Kat
I need the return pipes mentioned in the topic for citroen bx 1.4 1991 without power steering or ABS. If someone can provide them to me please tell me the price and if you can ship them to Greece. Thank you
jamescarruthers
- x 39
Re: Wanted: parts 96030258, 96046578, 96056235 for BX
Octopus 96030258 in stock
https://www.chevronics.co.uk/product/oc ... cba1185463
Back harness 96046578 (out of stock)
https://www.chevronics.co.uk/product/re ... cba1185463
LHM tank to doseur return 96056235 (in stock)
https://www.chevronics.co.uk/product/lh ... cba1185463
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
I have a new back harness here, its from a turbo diesel but is essentially the same the difference being there are 3 small return lines at the block (you could just blank one off) the smaller 3 return lines are 33/39/45 inches and the main return single line is 28 inches
Can ship to Greece no prob at cost
It has part number
14008
9054131
It has part number
14008
9054131
- x 60
I made my own return pipes out of some rubber fuel hose, plastic air pipe, 'T' & 'Y' connectors. I used the plastic air hose for most of it & the rubber fuel hose just to connect them together. If you're having trouble sourcing them, then that might be a way forward. Just make sure to connect the hoses to the same places on the car & LHM tank if you're going down that route. It might be worth removing your current return pipes and having a look at what connects to what & make some notes.
Hope that helps.
Hope that helps.
