Interference Engines
bx16trs
My Cars: 1986 BX16TRS Auto LHD
Post by bx16trs »
Hi all, been trying to find out whether the engine in my 1986 BX16TRS is interference or non-interference? None of the web refs I Googled show results for Citroen. TIA Brian
x 117
Re: Interference Engines
The anecdotal evidence is that when the cambelt fails valves get bent as a minimum and the camshaft can and does snap at the same time.
Call that interference if you like. I call it infernal bad design.
ghaddon1701
Post by ghaddon1701 »
1.6 XU engine is definitely an interference engine. Change the cambelt at the proper intervals and you need not worry.
x 138
Post by rutter123 »
Correct me if I'm wrong, years ago I had a mk1 vauxhall astra 1300 cambelt snapped due to seized water pump
No valve or cam damage, new belt and pump job done.
Or was I just lucky?
x 117
rutter123 wrote: Wed Aug 10, 2022 6:27 am Correct me if I'm wrong, years ago I had a mk1 vauxhall astra 1300 cambelt snapped due to seized water pump
My inference would it was a non interference engine. You never get lucky when there is a breakdown
