BX Head Unit
Jugostran
My Cars: 1989 Cimos-Citroën BX 16 TRS
2007 BMW 318d (the "company car")
x 51
BX Head Unit
Post by Jugostran »
Hey all, quick question.
A year ago I got a fairly cheap JVC head unit for my BX, and it has been getting on my nerves. Firstly, it doesn't turn on/off with the ignition. Secondly, the only way to turn it on and off is by holding the source button for 10 seconds. You can see how this would be really irritating if you make lots of short trips (like I do).
So, what are some possible solutions? Is there a way to wire it up to the ignition, or should I get a better head unit? If the latter is the case, which one should I go with?
Many thanks.
xantia_v6
My Cars: Peugeot 308 CC
Citroen XM V6 ES9
Citroen Xantia V6
Jaguar XJ-S V12
x 72
Re: BX Head Unit
Post by xantia_v6 »
Head units normally have 2 power feed wires, one unswitched and one switched. Do you have the fitting instructions?
I presume that the head unit has a DIN connector block with flying leads that you spliced into the BX wiring, or did the BX already have a DIN plug?
x 138
Re: BX Head Unit
Post by rutter123 »
You can pull a switched live by splicing into the ignition loom, thr rest i. e the perm live and ground are already there.
Jugostran
x 51
Re: BX Head Unit
Post by Jugostran »
xantia_v6 wrote: Thu Nov 17, 2022 1:43 pm Head units normally have 2 power feed wires, one unswitched and one switched. Do you have the fitting instructions?
I do have the fitting instructions. Pretty sure the BX already had a DIN plug, but it had to be rewired for the new unit (not completely sure as I didn't install it myself)
Jugostran
x 51
Re: BX Head Unit
Post by Jugostran »
rutter123 wrote: Thu Nov 17, 2022 8:16 pm You can pull a switched live by splicing into the ignition loom, thr rest i. e the perm live and ground are already there.
That sounds quite simple. I'll take a peek into the installation instructions and see if I can wire it up.
x 138
Re: BX Head Unit
Post by rutter123 »
If you remove or even look behind the centre console down by the pedal box you'll find the Ign switch loom 4 fairly thick wires poss 3 red 1 white, you can take a switched live from here.
