Hello,
I'm after two spare parts for my cars:
1. A near side headlamp for a 1991 TZD
and
2. An ABS sensor for a 1990 16v
Does anyone have these they are willing to sell?
Many thanks,
Brian
WANTED: near side headlamp and ABS sensor
Brian King
- BX 4x4 Owner. Brave.
RMS_TITANIC
- My Cars: BX
- x 3
Re: WANTED: near side headlamp and ABS sensor
Hi, I have a few pairs of bx headlights, not sure if they vary by model of BX though, I can go about getting some pictures tomorrow if you're interested.
- x 117
You will find that ABS sensors are like gold dust and almost impossible to find. When mine have failed I have usually found that the coax lead has failed internally in the area where they flex a lot. It is a simple job to splice in some screened cable to bypass the the failure.
The correct resistance should be about 1000 ohms - so that is the aim to get a correct reading after fault finding and repair.
deltic
- x 51
Are front and rears the same. Certainly the fronts are easier to remove!
