Yes, I know - hard to find, and possibly the only way forward if replacing may be early "sinker" Xantia estate rear cylinders. Have some feelers out, awaiting responses. Has anyone any they'd be willing to part with?
EDIT: Not the main problem, i find - I in fact have a strangely intermittent high pressure leak, horrible with car in high, virtually disappears at normal height. .
Potentially wanted: estate rear suspension cylinder(s)
- Our Trim Guru
- x 117
Re: Potentially wanted: estate rear suspension cylinder(s)
Sorry Dave i don't have one but when I had a failure on an estate, the typical corroding through of the estate's thinner wall, I just put a standard one on and never noticed the difference. I also drilled through the housing to provide a drainage hole to prevent the water and muck building up again and rotting through the replacement.
- Our Trim Guru
Cheers - used to have some standard ones I'm pretty sure but think they must be long gone or very deeply buried.
