Height corrector needed.
david troughton
Post by david troughton »
Front height corrector needed. Can anyone help?
x 60
Re: Height corrector needed.
Post by David »
Depending on what's wrong with your current one, it might be easier to contact Pleiades in Sawtry, Huntingdon & get them to rebuild it. They're good with many of the hydraulic parts & have fixed a few parts that I've had trouble with in the past.
Failing that, I think that they're the same parts that are used on the Xantia or XM, so if you're out of options that's something else to consider.
Hope that helps.
