west bay valver
greendale65
west bay valver
Post by greendale65 »
Hi all ,
Ihave had some pipes replaced all ok
next job cam belt
can i say this my car sat on my drive from october 2022
until now right the question is dont ask me why but before
the car went away electric windows stopped working dont know why
any ideas where to look.
x 116
Re: west bay valver
First a few questions to try to eliminate some possibilities before you have to get the multimeter out.
Is it all the four windows.
Does everything else electrical work, if not what is non functional too.
greendale65
Re: west bay valver
Hi all,
Sorry should have said it's all
four windows.
x 56
Re: west bay valver
Post by David »
Has the fuse blown for the 2nd ignition live? (There are 3 in total, 1 & 2 come on together on the 1st notch of the key, 3 comes on with the 2nd notch).
Do the brake lights, sunroof, dash illumination & map reading lights work? If not, then that'll be your issue. Otherwise all 4 windows wouldn't fail together as they're fed from different fuses and different relays, the only common link is the relay feed; which is L2 on the ignition.
Hope that helps.
greendale65
Re: west bay valver
Hi Thanks David,
will look into that after i get the cam belt sorted
Thanks
