Hi,
I'm looking for a rear axle off a BX 4x4. Would consider a complete car if it's easier.
I'm based in Gloucester but I have a recovery truck so collection is no problem.
Hoping someone might have something lying around where the transfer box has gone bang!
Thanks
Mike
4x4 rear axle (or complete car) wanted
mikeparry
- My Cars: Citroen C15 Romahome
Peugeot 309 estate
- x 60
Re: 4x4 rear axle (or complete car) wanted
Why do you need the axle; what has broken on yours?
Remember some of the parts are shared on the Peugeot 405.
If you’re really stuck, then you can use the basic axle from a 2WD car & do some cutting & welding to make it suitable for the 4x4, or repair yours with bits cut from one. Once the arms, diff & hydraulics are out of the way, it doesn’t look much different from a 2WD axle.
Hope that helps.
Hope that helps.
mikeparry
Peugeot 309 estate
Hi David. Thanks for the reply. I've got a slightly mad project which I'm making RWD I don't have an old 4x4 axle to play with. I have a few 2wd axles and I have a BX 4x4 diff, but I'd still need trailing arms, driveshafts, diff cradle, along with modifying the beam. Ideally I'm looking for a car where the transfer box has blown up but the axle is ok. Cheers
- x 60
Good luck with the project.
You may have difficulty sourcing 4x4 parts.
There’s a project that’s been mentioned about using the front struts on the rear of the BX, for 4 wheel steering IIRC. If you can’t find anything else, then you could always really modify the car & go down that route, or maybe weld something to keep the hubs straight if you don’t want 4WS.The hubs are all the same, so you’d just need longer shafts. Surely a driveshaft specialist could help with them & the prop shaft. The axle would just need a bit of welding to hold the rear diff. You’d need to modify the fuel tank too.
