clean throttle valve
LouBX
My Cars: Citroen BX 14 TGE Tecnic 1989
Post by LouBX »
Hello everyone,
Today I bought some throttle valve spray to clean my throttle valve. Do any of you have any tips on the best way to proceed? Maybe there is already a post here in the forum? (I'm new here ;) ) I know that I have to remove the intake manifold, both the air filter and the throttle body. Should I also remove the hoses?
Thanks in advance for your answers!
saintjamesy89
My Cars: 1985 Citroen BX19 GT
1990 Volvo 740 2.3 GLE Estate
2013 Nissan Leaf Acenta 24Kw
x 198
Re: clean throttle valve
Post by saintjamesy89 »
Hi LouBX, what is it that you mean by the throttle valve - are you referring to the carburettor? The two red arrows look like they point to the crankcase ventilation hose and within the circled area is the air filter box, carburettor and housing that connects those two.
If you wanted to clean the carburettor, just take the plastic part off of the top of the carb and air filter box and spray clean the inside with the engine running, you can also remove the crankcase breather hose and give that a clean.
2007 Lexus RX 400h SE hybrid
2013 Lexus RX 450h Luxury
