Long time reader, first time poster here.
Never thought I'd see the day that I'd post something on a forum, but might be useful!
Right, so. As the title implies, all of my gauges have stopped working completely.
Except for the fuel gauge, which is always jumping to Full even if it's really not.
I have a little step-by-step plan to troubleshoot this issue.
First up, cleaning the connectors and contacts on the back of the cluster. Already took the entire thing out and removed it from it's plastic shell (kinda looks like an early 80's computer casing haha!)
If that doesn't work, I'll check the fuses again and I'll also check the relays. Not sure which one it is yet, but maybe someone here can show me!
After that, earthing points. Now this is the reason I'm posting here.
Because I have absolutely NO idea where these points are. I've found one on the right side of the engine bay, connected to some blue plastic box?
But that one looks fine to me and I doubt it's connected to the gauge cluster.
Let me know if you know where these earthing points are or if you have any other ideas on this issue!
Thanks!
