Heater control hard to turn
assembled
- My Cars: 1991 Citroen BX TZD TURBO 4WD*
*aspirational - x 2
Hi, I have been sorting out my BX after winter and wanted to tackle the hard heter control knob. Got it all in peaces, all cables out. Temperature control is moving two flaps and valve. It seems that both flaps and especially the upper one are not smooth. Valve seems rather ok. Is there anything that can be done about the flaps without panel out and splitting the unit? Car has sat for many years unused, I suspect that did not improve smoothness. It’s left hand drive, so good access to everything on both sides. Cable is fine, so is the panel controls.
1991 TZD Turbo berline
Ex 1992 TZD Turbo berline, aircon, ABS
Ex 1989 GTi 4x4 berline, ABS
assembled
*aspirational - x 2
Re: Heater control hard to turn
What if I leave flaps in Hot position and have dial control only the valve? This way i would retain control but reduce risk of snapping something until I get a chance to sort out the flaps.
panky
'88 BX GTi (a long time ago) - x 174
I doubt it would do any harm and at least you would have some control.
- x 116
The right hand heater knob is always stiffer than the other two. The only damage that can occur would be to the knob itself. These can and do split around the spindle.
