I've kinda sorted the rear and dosed the runners with anti-rust. It works now even if it sounds crap!
The fronts are electric and the drivers door is real pain. It goes half way up and skips on the motor cog
I'm assuming some of the control arms are bent somewhere (although they looked straight) and when the window gets to half way up it isn't pushing straight. As a result the winder gear arm must be running at an angle to the motor cog and eventually pushes itself up over the motor cog.
Has anyone had this problem and solved it? I'm going to have another go tonight but I don't really expect to solve it.
