WANTED - Kickdown cable 1992 BX16 TGS Auto
trecasi
My Cars: Citroen BX16 TGS Auto
Citroen C3 Aircross (wife's car)
Post by trecasi »
I'm trying to find one with correct length kickdown cable to go from Solex twin choke carb to ZF 4HP14 autobox. The one that arrived with my replacement box isn't long enough (by about one metre!) so no kickdown at present. Would probably be around two metres I guess.
panky
'88 BX GTi (a long time ago)
x 174
Re: WANTED - Kickdown cable 1992 BX16 TGS Auto
Post by panky »
The description is a bit vague but it might be worth a call
https://www.chevronics.co.uk/product/ci ... own-cable/
kaivatony
My Cars: BMW I8
Post by kaivatony »
Hi there, I had a similar issue when swapping out my autobox on a '91 BX16. Ended up sourcing a kickdown cable from a scrapped ZX 1.6 auto — it had just the right length to reach from the Solex carb to the ZF 4HP14. You might want to check compatibility with early ZX models or even some 405s. Hope that helps!
Hello, I'm Tony Kaiva.
