Wanted rear brake calipers
Kieron g
My Cars: 2001 Citroën berlingo multispace 1.9d
2000 Citroën berlingo multispace 1.8i
1988 Citroen BX 1.6 RS (sun seeker)
x 10
Post by Kieron g »
Looking for a pair of rear brake calipers for my 16rs.
One of mine has a seized piston, both have the pipe fitting sheared off flush which I can't shift.
Also source / lead for 3.5mm pipe would be much appreciated. Thanks
panky
'88 BX GTi (a long time ago)
x 175
Re: Wanted rear brake calipers
Post by panky »
This guy might be able to help with the pipe and seals
[email protected]
Kieron g
x 10
Post by Kieron g »
Thanks for that. Much appreciated, will check it out
Kieron g
x 10
Post by Kieron g »
The link to classiccargeek came up trumps. I've ordered a 25ft length of pipe from him, I already picked up a second hand flaring tool for the pipe so fingers crossed I can now make the rear brake pipes.
Thanks again Panky
x 117
Kieron g wrote: Mon May 12, 2025 11:51 pm The link to classiccargeek came up trumps. I've ordered a 25ft length of pipe from him, I already picked up a second hand flaring tool for the pipe so fingers crossed I can now make the rear brake pipes.
Thanks again Panky
I have got a list somewhere of the lengths of all the pipes if that helps
x 117
Kieron g wrote: Sun May 11, 2025 11:06 pm Looking for a pair of rear brake calipers for my 16rs.
Autodoc have stock of calipers in Germany if you can't find stock or 2nd hand here.
Kieron g
x 10
Post by Kieron g »
Thanks Jaba.
I never really made complicated pipes before, theres a guy used to work on these cars said I should use a socket and wrap pipe around it to get the spiral.
For length thought to use a piece of string along old pipe and add a bit.
Thanks for lead on Autodoc will definitely check that out
Kieron g
x 10
Post by Kieron g »
Just updating this thread.
Eventually managed to source a pair of used rear calipers which seller was willing to post.
I tried purchasing new.
Autodoc took my order then refunded it for some reason, I think because the parts were in Germany and they didn't want to post.
Mister Auto say they have these but the order won't go through.
Have to say servicable BX rear brake calipers along with good interior lights are amongst the most difficult parts for any car I've tried to get hold of.
